https://guitarsgarden.com/collections/f ... urst-color
I have been GASsing for a Vee for several years.
After looking at bang for buck choices in a set neck Vee or possibly a mid grade Rhoads style, I had been looking for the right used Dean '79V for the right price, unless something else came along.
I had moved on as nothing came up.
Until now - @LightWingStudios thread got me interested, and here I am.
I would have preferred the string through, but the TOM is fine.
Verifying the 24-3/4" scale = trigger pulled.
I hoped for a decent budget guitar with at least good bones, and it delivers.
The Good:
Delivered undamaged, no obvious issues.
Neck straight, tuners mounted straight, neck back angle looks ok.
Fit and finish looks pretty good. The stain on the back looks a little smudged or something but it is minor.
Around 7-8lb range, balances great standing = no neck dive!
Plugged it in to check operation, everything functions (but it sounded awful).
The neck profile is a medium C I guess, a little on the thicker side compared to the C profile on my Squier Classic Vibe strat.
I like this a lot, but thats just me.
The tuners are Jin-Ho brand, commonly used as OEM on, I want to say the higher end of budget imports.
They are quite good and I have no plans to change them.
The pots are full size; the taper sounds pretty even. They turn smoothly but are too stiff too spin with my pinky.
I shot a little Faderlube in them and the tone pot is fine now but both volumes are still a little stiff; I may spray them again.
The nut is listed as bone; it may be or it may be a denser synthetic.
Nuts need to be fitted, and this takes labor time and skill not feasible with cheap guitars. The slots are very high and tight. The strings dont ping but they do bind.
After some nut file work, I dont feel the need to change it, though I will file the top down as the strings are pretty deep in now.
I think the low e was still slack when I took the pic.
The fret ends are rounded and dont stick out; they are very smooth.
I didnt rocker or straightedge for level, but find no buzz so far.
Hardware / overall product quality is pretty good, there is no real Bad or Ugly.
There is some finish cracking around the bass side tailpiece insert, but there is no slop in it or the bridge.
The out of the box set up was pretty bad, or none at all, just assembled by eye.
Action not unplayable high - but the bridge had the treble side higher off the deck than the bass side.
This caused a moment distress as I re-sighted the neck for a bad set or twists, etc.
All is well.
The bridge is now all the way decked on the treble side.
I would rather have it go down to string buzz and then adjust up, but it is ok.
I could grind a little off the bottom if need be.
The relief was way flat; I had turn the truss rod quite a bit to get some relief, but the plus is the truss rod turns and the neck responds.
I mentioned it sounded awful at first - the intonation was either a bit, or way off on all strings.
I dont care as I do my set ups anyway, just reporting what came out of the box.
There is a black pickguard, a 90 deg cable and truss rod wrench in the box.
I have not pulled the pickups out yet, but plan to shield the pickup and control cavities, as it is a bit noisy.
But so is my Gibson Studio LP. Gonna shield that one too.
I dont hate or love the pickups but this guitar is a pleasure to play, stays in tune, and I find no discomfort seated given where the jack is located.
For less than $250 to my door this is a complete WIN.
NGD: Firefly FFLV
- solteroblues
that looks really good! Looks like the same color as my first ever Agile 2000 honeyburst.
WANT!
After 2 weeks of daily play, I've got to say I am really happy with this guitar.
The only thing that was changed besides strings and setup was filing / dialing in the nut slots.
I'm still undecided on the pickups but have no strong urge to change them.
- LancerTheGreat
- Gearlist: -Guitars-
These look solid as fuck, and I'm always glad to see people joining the Flying V club, extra glad to see someone satisfied about it too.
Also LOVE that color dude!
- LightWingStudios
- Site Admin
FINALLY got some time to work on my Firefly "V" today...
https://guitarsgarden.com/collections/f ... arent-blue
Wilkinson Locking Bridge installed, Neck oiled up (4 coats) and still looks dry so maybe one more and let it sit for an hour, Nut Sauce added too. Still have to have to Shield the PUP and Controls Cavities. Stringing it up a little later, adjust action and intonation. Truss Rod is spot on from the factory! Stock PUPS ain't bad so I'll let them go for a while and see. So far I'm "ALL IN" to this guitar for UNDER $300 including shipping.
RIDICULOUS!
Next up will be "The Aerosonic".
RIDICULOUS!
- LightWingStudios
- Site Admin
Did the FINAL STEPS of the "V" today...shielding of PUPS cavities. I looked at the Pots/Switch cavity. Shafts are a bit short
but just long enough to get the nuts and washers on. I didn't think I would still be able to get them in with the shielding installed
so I passed on that. First time doing this stuff...not bad for a "Rookie".
I ended up going BACK to the Stock Bridge because of difficulties getting the Action set properly. I couldn't get the Roller Bridge
low enough in tandem with the Tailpiece so that the strings didn't hit the back of the bridge. I may try it on another FF but I do
have to say the Stock Bridges ARE NOT BAD.
Action and Intonation completed now after slapping a set of 9's on it.
Playing clean it rings like a farkin' Bell and has some decent Testes when "The Dirt" is applied.
BEFORE...AND AFTER SHOTS!
NIce work!
I'm still playing mine everyday.
I hope to shield it this week, but currently my Jackson dinky is on the bench to upgrade the stock licensed Floyd to a Gotoh 1996.
