The hip-end screw which holds the strap peg was coming out.
I had glue and toothpicks laying around the house so I figured that I'd try this (see below). I'll let it dry for 24 hours, snap off the 'picks, sand and then drill a small starter hole to guide the new screw.
Thoughts?
Strap peg hole - It can be done better, I'm sure.
- ronnx
- Gearlist: Agile, Squier, Ibanez, Italia, Fender., Peavey, Epiphone and Partscasters.
Toothpicks are great for filling pick guard screw holes or string retainer holes or tuner screw down holes on the back of the head stock. For the larger strap screw holes I get the small dowel rods at my local hardware store and if they are a little too large for the holes I will grind them down on my bench grinder. If you don't have a grinder, you can file or sand them to the proper size.
I've used toothpicks and glue to repair wallowed out screw holes in wood of all kinds including guitars as long as I can remember I just never drilled starter holes for the screw and that sounds like a great idea.
SHADE TREE WOOD HOLE REPAIR BY THE TOOTHPICK WHISPERER
^ That is a great fix, Tommy!
I perform a variant on this, because I sometimes had problems drilling into the dried wood glue. I put butcher's wax on the strap screw first. The put in the glue, toothpicks and flush cut the picks. When the glue has cured for 10 or 15 minutes, I install the strap button and screw. Unlike solid wood, the toothpicks crush enough to make way for the screw. Using this method, the glue shapes to the screw and since you use the wax on the thread - it can still be screwed in and out.
