Agile AL3k Spalted
Probably my favorite Agile I've ever owned. But also the heaviest. Got this as a bstock cause it has a little ding on the back.
Mods include
Shielded cavities
Treble bleeds
Bourns pots 250k neck 500k bridge
Gotoh Nashville tune o matic nickel
Lightweight aluminum stoptail nickel
Switchcraft jack
Switchcraft 3 way
Custom poker chip
Abalone top knobs
A5 neck p90 7000 44awg p94 style nickel ring
A5 c8 bridge 5500 42.5awg nickel ring
Push pull neck tone does in series out of phase
Bridge volume push pull splits humbucker with 6.8k resistor
Buddha's mod projects
- dabbler
Me too!! I didn't even remember Agile having any spalted models. But I ain't mad, cause I have this:
Not the best spalt, but for what I paid, I can live with it.
Agile 3100 Silverburst
Got this from guitar Center used back in 2020 for 250ish. It was pretty dirty and the nickel hardware was tarnished. I swapped out the hardware to chrome. I didn't want all my silverbursts to be just like Adam Jones guitar so I added a beauty ring to the bridge pickup and went a8 for the magnet. I had to reverse the neck on this one cause I accidentally cut the leads a little short.
Mods include
Graph tech bridge
Switchcraft 3 way
Switchcraft jack
Custom poker chip
Shielded cavities
Treble bleeds
.01 pio neck. 015 pio bridge
Volumes push push split humbuckers with 6.8k resistor
Neck tone push push for in series out of phase
Neck a4 humbucker 5000x2 42.5awg
Bridge a8 humbucker 6750x2 44awg
Mods include
Graph tech bridge
Switchcraft 3 way
Switchcraft jack
Custom poker chip
Shielded cavities
Treble bleeds
Looks sharp! From the neck pickup specs, the sound is probably sweet and balanced?Buddha Pickups wrote: ↑Fri Jan 17, 2025 8:21 pm Agile 3100 Silverburst
Mods include
Graph tech bridge
Switchcraft 3 way
Switchcraft jack
Custom poker chip
Shielded cavities
Treble bleeds
Thank youandrewsrea wrote: ↑Tue Jan 21, 2025 10:19 amLooks sharp! From the neck pickup specs, the sound is probably sweet and balanced?
If I actually planned ahead and was not flying by the seat of my pants when I mod these I probably would've preferred the neck to cosmetically match the bridge but oh well.
Yes, pretty balanced. I normally mismatch a little when in that paf ish wind range but the 42.5 gives it a little low end fat boost over the standard 42. Gets you closer to a p90 ballpark if doing a hum sized p90 too vs going with 43 like we normally have to do on hum sized p90s.
Have you ever used 42.5? I can't find much info for it online
I have not used 42.5 gauge, at least purposefully. I've done very tight tension builds that I was pretty sure was stretching the wire a bit, which reduces the diameter. I thought I saw you do some builds with bigger wire, like 40 gauge?Buddha Pickups wrote: ↑Tue Jan 21, 2025 9:19 pmThank youandrewsrea wrote: ↑Tue Jan 21, 2025 10:19 amLooks sharp! From the neck pickup specs, the sound is probably sweet and balanced?
I did use 40ga alot when I first started but rarely use it now. I used 41ga for my Agile Harm toaster pickups and they sound very jangly. I think 40ga humbuckers ended up in the 4k range. They sound great with p90s using ceramic or a5 mags too.andrewsrea wrote: ↑Wed Jan 22, 2025 11:47 amI have not used 42.5 gauge, at least purposefully. I've done very tight tension builds that I was pretty sure was stretching the wire a bit, which reduces the diameter. I thought I saw you do some builds with bigger wire, like 40 gauge?Buddha Pickups wrote: ↑Tue Jan 21, 2025 9:19 pmThank youandrewsrea wrote: ↑Tue Jan 21, 2025 10:19 am
If u ever want to trade for some 42.5 I have an extra spool (i bought 5 or 6 5lb spools a few years ago on a great deal cause they were damaged in shipping. You may have to cut through the outer layer and unravel a bit to find the finish on the spool) but just let me know!
Firefly Tobacco burst
Been wanting a les paul with a maple board since I sold my natural Douglas Hawker (i wish I kept it!). I always planned on grabbing an Albino Agile or the Albino Firefly they had recently but I never did. This one popped up for about 170 shipped over the holidays so I grabbed one.
Matte finish that magnetizes fingerprints but otherwise feels great. Locking tuners like all Firefly les Paul's come with now.
Pickups are a mix of a bar and rods. Cream coil has magnetized a5 rods but also a bar magnet magnetizing the black slug coil as well. Sounds very stratty when both split in the middle position.
Mods include
Shielded cavities
Treble bleeds
500k push push pots (IKN like $2ea!)
Gotoh style tune o matic
Switchcraft 3 way
.01 Pio caps
Volumes split humbuckers with 6.8k resistor
Neck tone does in series out of phase
Bridge tone has a strangle esque mod that puts a .015 on when pushed
Neck zebra a3 bar 4500x2 42.5 a5 rods in the cream
Bridge zebra a4 bar 5500x2 42.5 a5 rods in the cream
Mods include
Shielded cavities
Treble bleeds
Switchcraft 3 way
.01 Pio caps
Chibson Natural 3 pickup LP
Grabbed this on ebay over the holidays for 205 shipped on ebay. Surprisingly decent quality for 200 bux. The electronics were garbage.
Mods include
Shielded cavities
Treble bleeds and .01 pio tone cap
Frampton wiring 3 volume 1 tone
Switchcraft 3 way and jack
500k push push pots except 250k volume for middle
Neck vol push push splits humbucker with 6.8k resistor
Bridge vol push splits humbucker with 6.8k resistor
500k master tone puts middle pickup in series/out of phase with neck pickup
Middle volume Bourns 250k
I need to start writing down my winds before posting cause I'm not 100% on what each pickup is but I think it was
Neck a4 5000x2 42.5
P94 a4a5 6750 44
Bridge 6000 43 and 42.5 ceramic with flanker
Mods include
Shielded cavities
Neck a4 5000x2 42.5
P94 a4a5 6750 44
Epiphone Wildkat
I think it's a 2011 based on the serial number but not sure, I got it new from musiciansfriend around that time.
I took out the master volume when I rewired it. It now just has the 3 way, neck volume, bridge volume, and master tone.
Mods include
Wilkinson roller bridge
Bourns pots 500k bridge 250k neck
Bridge push pull splits humbucker with 6.8k resistor
Neck push pull does inseries out of phase
.01 pio cap
Treble bleeds
Neck p90 a5 7500 43awg
Bridge hum 6000 43 6000 42.5 a5 with ceramic flanker
Mods include
.01 pio cap
Treble bleeds
IYV Green LP
Picked this up off ebay a couple years ago for under 100. Feels similar to Douglas quality, not Agile quality. The tuners are a bit tough to turn on a couple strings, maybe just needs a little oil in the gears, we'll see.
Mods include
Treble bleeds
Shielded cavities
500k alpha Volumes
500k bourns tones push pull
Bridge tone splits humbucker with 6.8k resistor
.01 pio neck .015 pio bridge
Ceramic x2 bridge 8000x2 44awg
Black pole screws
Aluminum stoptail
Mods include
Treble bleeds
Shielded cavities
500k alpha Volumes
Black pole screws
Aluminum stoptail
I feared that on the tuners but will have to try a replacement next time I change strings.
Westcreek Cerebrus
Picked this up as a bstock/customer return off ebay for 150ish if I remember correctly. Definitely not in my normal wheelhouse but I wanted something to try actives in so thought this would be perfect. The 9v does not exactly fit in the cavity cause the pots are long shaft so I chose the control cover having a little bend cause it won't screw flush vs knobs being too far off the body.
Mods include
GM Active humbucker set
Alpha pots , 25k and a cheap chiclet .1 cap
Mods include
IYV Rick clone
Mods include
Shielded cavities
300k bourns pots 250k neck tone for push/pull
Switchcraft 3 way
Switchcraft jack
.01 pio .015 pio caps
Treble bleeds
Neck tone pulled does in series out of phase
5600 44awg neck a5 rods and dual a5 bar mags
6000 44awg bridge a5 rods and dual ceramic bars
Mods include
Shielded cavities
Switchcraft 3 way
Switchcraft jack
Treble bleeds
Glarry Andy Summers Telecaster
Picked this up recently on a whim after watching an Andy Summers/Police documentary so I was inspired. I had to route a little for the neck bucker and i swapped the 3 saddle bridge for a 6 saddle one with brass saddles. I was out of 3 way switches so I put in a 5 way. Certainly not my best playing guitar but no sharp fret ends and its very light. Could definitely use a new nut and new tuners.
Mods include
Shielded cavities
5 way switching- cap, series, neck, parallel, bridge
Master volume splits humbucker
Master tone switches .01 to .05 cap
Neck humbucker a3 7.5k raw nickel cover
Bridge hfv a5 7.5k brass baseplate direct mounted
Switchcraft jack
US style 5 way
Mods include
Shielded cavities
Switchcraft jack
US style 5 way
- tobijohn
Are the pickups surface mounted? I can't tell from the pics.I can't tell from the pics
Good stuff Tim. Those Ric copies are cool.
- tobijohn
Buddha Pickups wrote: ↑Fri May 23, 2025 11:43 pm
Btw, if youre logged in u can click on any Pic and zoom in
Hey thanks
I really wanted to swap the bridge but its a pretty non standard setup. I think they still have this one for 175ish on Amazon
- tobijohn
Any reason why? The one on it looks like the standard Rickenbacker style bridge.Buddha Pickups wrote: ↑Sat May 24, 2025 9:02 pmHey thanks
Just dont like it. I'd prefer a straight up tune o matic, Nashville styletobijohn wrote: ↑Sat May 24, 2025 9:09 pmAny reason why? The one on it looks like the standard Rickenbacker style bridge.Buddha Pickups wrote: ↑Sat May 24, 2025 9:02 pmHey thanks
