NHGD!
Yes, I finally landed one of the Eart guitars.
I picked it up yesterday. The good:
- Nice neck. Think Fender moden C with a flatter radius;
- Lovely stainless fretwork, with nicely rounded fret ends;
- Looks great, if you're into that sort of thing, which I am. My son said it is "sick, bruh!";
- Light weight and VERY resonant with great sustain -- feels alive in my hands;
- Very comfortable to play;
- Stays in tune really well.
The bad:
- The knobs aren't original;
- The jack seems to be a bit sensitive to pressure and can cut out if you nudge it -- easy fix;
- The pickups sound like they have a blanket over them -- they're not bad, just muffled. I need to check out the electronics. New pots could work wonders;
- The action is a bit high, which is fixable with adjustments/shims;
- My son says things are "sick, bruh!"
Then there is the big bad, which is that the truss rod seems to be fully tightened, and there is still a little relief. I'll check it again as it gets more acclimated to my basement. Perhaps lighter strings can help. At any rate, I like having a little relief, so all good.
All in all, I like it. Next step is to secure the appropriate stainless steel and hardened steel fasteners to replace the stuff it came with and bring out the best of what it has.
bc rich
Congrats , thats sick Bro
bc rich wrote: Sun Jan 09, 2022 3:13 pm Congrats , thats sick Bro
Now you're just yanking my chain.
I took off the back cavity cover and, yep, there are electronics in there. It all looks fine, and the pots say they are 500K pots (full-sized, no less), so there goes my theory that the pots were the wet blanket over the pickups.
I guess I'll need to consider better pickups down the line.
Bullcat
Dude, what a top that's wicked!
Joined AGF May 11, 2015
Nice score!
Bullcat wrote: Sun Jan 09, 2022 5:00 pm Dude, what a top that's wicked!
Poplar burl is awesome looking. I have also seen flamed poplar, which was nice too.
This thing half has me thinking of a poplar burl veneer for the Flying V kit I got for my birthday.
Lots of work but the payoff will be big.
Yes, but so would plan A, involving Duplicolor Metalcast.
Think dark green sparkles....
Tiga
That's pretty cool - never owned a headless guitar but see the appeal. Hopefully someday. I keep reading on how nice the fretwork is on the EART models.
The fretwork is very nice.
I spent some time on lowering the action last night. Still needs more, and I think there is more room, but we might be getting into the realm of shimming the neck. If I can get some hardened/stainless screws together soon, I'll dive in to the bridge and a full setup. The problem is I need to pull some screws out to measure, which could put it out of commission for a little while.
Also, this thing is easy to play. I can pull stuff off cleanly on this guitar that I can't on others.
jam
That does look pretty cool. Nice!
jam wrote: Wed Jan 19, 2022 10:04 am That does look pretty cool. Nice!
Thanks! It's rapidly becoming a favourite. Just need to work out a couple details.
I got the strings lower, and it is brightening a tad. I will likely need to shim the neck to get the action a hair lower.
And once I get my assortment of improved fasteners, it should per up a bit more.
