Semi Hollow, Metallic GREEN, Mini in Neck, HB in the Bridge. Mini is great...HB gotta go...too microphonic.
Added a TP-6 Tailpiece, 9s and have a Gibson 490T waiting in the wings. Frets are Stainless Steel with ball ends.
Custom Truss Rod Cover. Tuners are quite serviceable and weighs in at just under 7.5lbs. $249 SHIPPED.
NGD: "Green Goblin" Firefly Florentine Les Paul Has Landed!
- LightWingStudios
- Site Admin
You're on a roll
That's a cool pickup combo too
You truly are a Firefly freak in the same manner as the old Agile freaks. Too bad they do not have B stock sales. Enjoy the HNGD. I have that one Firefly semi and it is working out well for me. I have a set of pups being made and then it will be better. Jury is still out on the tuners. I need to play it for an entire rehearsal with strings that have settled and then make a decision. Chances are I will upgrade.
- LightWingStudios
- Site Admin
RE: "Locking Tuners"...Look on ScamAzon from Musiclily...inexpensive and work great. My goal with these guitars is that AFTER all the Mods are done it runs me $500 or LESS. Alot of them need nothing but that depends on what you playing style calls for. If you're a "High Gain Freak" PUPS definitely need to be swapped.tonebender wrote: ↑Sun Jan 15, 2023 12:36 pm You truly are a Firefly freak in the same manner as the old Agile freaks. Too bad they do not have B stock sales. Enjoy the HNGD. I have that one Firefly semi and it is working out well for me. I have a set of pups being made and then it will be better. Jury is still out on the tuners. I need to play it for an entire rehearsal with strings that have settled and then make a decision. Chances are I will upgrade.
I installed 18:1 Grovers and custom wound pups. It should be a mean machine.
