Loaded H-S-S Strat Pickguard
AMI Loaded Pickguard H-S-S - $160 AGF price, delivered.
AMI 'Divinity' humbucker (7.3K Alnico2 magnet) matches perfectly with the AMI 'EJ' single coils (middle: 6.35K Alnico 2; neck: 5.8K Alnico 5). Typically going from humbucker to the singles can be cumbersome on these H-S-S setups, but this is smooth!
Depending on the amp, the 'Divinity' can do any style (Van Halen 1 Frankenstein used a similar pickup). The 'EJ' singles are shimmery and bell-like. Super stratty.
Volume - Tone 1 (Middle and Neck) - Tone 2 (Bridge w/ PP custom coil cut). High quality pots (Gibson & CTS) & tone caps specifically selected for this build. CRL 5-way switch. Switchcraft jack. White 3-ply 11 hole pickguard, white bobbins and cover, white knobs and switch tip.
Fully tested and sounds great!
This was custom ordered by a friend, who changed his mind and ordered a S-S-S with AMI 'EJs'.
For those wondering who AMI is, it is my hand-built products - Andrews Musical Innovations. Pickups are warranted for life to the original purchaser.
