High Headroom Boost - complete
Finally got to tweaking and painting this. I think I shared the artwork around the first of the year. Images nicked from the internet for personal use.
It is a tweaked 27v full-range clean boost. The tweaks are less noise, fixed a treble circuit glitch and experimented with a range control, which tightens up the bass frequencies. Next version will forego the range and change the 'treble' for a mid-boost.
AMI 'Max Headroom':
Wicked skillz.
