Not really sure how the plural of "Jockey" is spelt, but... I came across this when perusing one of the 8-bit YouTube channels that I'm subscribed to. It's an inexpensive, high-temp (400°C max), USB powered soldering iron. Or I should say; a soldering iron that uses a USB connector for power. It requires at least 12V, so you can't use a regular 5V USB power source. The iron costs: $24.99 and the power supply is: $35.99, but you can use any power supply that puts out 12V through USB.
I think it's made by the same company that makes the Pine Phone.
