My latest completions:
- AMI 'Rawk', which is a boost-limiter like Angus uses with a couple tricks to quiet it down.
- AMI 'Dumblicious', which is my modified Timmy. This one came out fantastic sounding and the new owner of this one will be applying the Dumble-like graphics, using a laser-engraver.
- AMI #10, which started as a Tube Screamer TS10, that I added three soft-clip modes: stock symmetrical -open LED - slightly asymmetrical. It has and extended range of gain and louder volume on tap. It can do the traditional TS10 and then some.
Triple-play of Pedals
Very cool! I'm quite intrigued by the Rawk. Got any demos or sound clips?andrewsrea wrote: ↑Sat Oct 30, 2021 12:49 pm My latest completions:
Aaron
"What is perfect pitch?"
RiverDog wrote: ↑Mon Nov 01, 2021 2:49 pmVery cool! I'm quite intrigued by the Rawk. Got any demos or sound clips?andrewsrea wrote: ↑Sat Oct 30, 2021 12:49 pm My latest completions:
Thanks! Not yet.
First off, this is not Angus in a box. So it won' make your FDDR amp sound like a '75 Marshall JMP Super-lead through a full stack. It emulates 'the' circuit which is found in Angus' secret weapon, his Shaffer-Vega wireless transmitter.
Which is basically two stages of boost. The first stage has a optoisolator (an LED + light sensitive resistor) controlling the gain of the first stage as a limiter (a fast & hard compression only on very loud notes). The second stage is a crushing 31dB, very low-impedance boost.
You set your British-style amp to a nice (not too much) distortion, then back down it's gain a little - plug your guitar through this and set for a bit of limiting and boost to taste. Voila - AC/DC!
Sounds tasty! I've been interested in that "effect" ever since I learned about it a few years ago.
Aaron
Thanks my friend. I'm totally digging it!
Aaron
