I put the David Gilmour wiring in my #1 Strat
I put the Eric Johnson turbo wiring in my #2 Strat
I put the plain Eric Johnson wiring in my #3 Strat
Upgraded three strats... (cont)
- Perfect Stranger
~Jim~
Even great harmonica players suck half the time!
- Perfect Stranger
- Perfect Stranger
The regular is just a regular ol' EJ harness. The Turbo has the solderless switch, vintage wiring, and a vintage p-I-o Cap.
Basically cost twice as much, but sounds exactly the same. More a name than a different tone.
I do like the EJ tones though. The Gilmour sounds good, but doesn't seem as versatile to me.
Doing the upgrades was nothing heroic, basically just drop-ins and install the pickups. ANYONE could do it....
~Jim~
Well whaddaya know... My Strat has the Gilmore mod, and I didn't even know it was the Gilmore mod.
I didn't find it quite as useful as I imagined, either... I like having the bridge and neck pickups on at the same time, but engaging all three isn't nearly as epic as I thought it would be. It's pretty useless, actually.
I appreciate you explaining the 'turbo'. I had never heard of it.Perfect Stranger wrote: ↑Wed Oct 13, 2021 6:25 am
Like @golem stated, I personally find the EJ wiring in the Strat is mandatory. I have been recently doing work for a local guitarist named TJ and yesterday he told me he never uses the bridge pickup on his Highway 1 Strat, but actually uses the bridge position on his EJ model. I said it is because of the tone being moved from the neck to the bridge position. It tames that position.
The Gilmore mod (actually Craig Anderton mod) can be good for the bridge-neck combo, if you have a bridge pickup that leans into Tele territory. If you copper tape to the underside of your pickguard at the bridge pickup and ground it, then affix a grounded steel plate to the bottom of the bridge pickup, using silicone caulk as a non-conductive adhesive - you can get close.
- Perfect Stranger
Thanks so much....Mossman wrote: ↑Thu Oct 14, 2021 12:02 amWell whaddaya know... My Strat has the Gilmore mod, and I didn't even know it was the Gilmore mod.
~Jim~
- Perfect Stranger
One thing I think I did forget, and I don't feel like looking to see. Some of the pots and caps values changed which can, as you know, change the tone quite a bit.
~Jim~
I'm not really sure what you mean by that, Jim.Perfect Stranger wrote: ↑Thu Oct 14, 2021 1:09 pmThanks so much....Mossman wrote: ↑Thu Oct 14, 2021 12:02 amWell whaddaya know... My Strat has the Gilmore mod, and I didn't even know it was the Gilmore mod.
