Going on a Bender...
Apparently using Indonesion rubber as a replacement for Brazilian Rosewood didn't go exactly as planned
Might want to think about giving the truss rod a couple turns to the left . . . like a couple dozen turns.
You'd think string tension would bend the neck the other direction?
mickey wrote: Fri Oct 02, 2020 7:12 am You'd think string tension would bend the neck the other direction?
Maybe they're using Image
