Picked up a chunk of maple from Westonbirt Arboretum.
Day one of the build was sketching out some rough shapes, from this I plan to cut and carve.
Day two was a lesson in band saw etiquette. Had to straighten my blade as a long cut down the grain closed up and trapped the blade.
Got a basic shape out, almost . . .
Also, I need a bigger bandsaw than a 250mm throat
The slow build thread - my first ever build
Nice. look forward to watching it.
Is it gonna have a beer holder?
Now there’s a thought, could do with an excuse for my lousy playing!Partscaster wrote: ↑Sun Sep 27, 2020 1:50 pm Nice. look forward to watching it.
- TheIrritableLuthier
I dig the body shape. I'm looking forward to watching this build!
- solteroblues
kudos to you! I bought all of the equipment to build one, a ton of wood to build several, some templates to get good shapes, and I've never even started.
The best thing anyone ever told me was “it’s only wood”. Have fun! The one I built is my avatar, and I have a thread here someplace dedicated to number two.... heeheehee... number two.
Limited chance to get to work on this with the puppy, but started to form the outline a bit more.
The wood has some slight Spalton which will make for some interest, I plan to Danish oil it and leave it at that.
A long way to go, belly cut, arm cut, and some carving of the horns coming up.
Picked up a Shinto Saw Rasp for the rough shaping, and then using a Triton oscillating bobbin sander with various grades.
Here’s the blocker
Are you building the neck from scratch?
I chose to build my neck first, so I could cut the pocket EXACTLY for that particular neck. I really enjoyed making the neck. It’s not that hard, just takes patience, but it’s very rewarding in the end.
I'm going to give it a go, yes!, I'm leaving plenty of material at the neck joint to make sure it works out in terms of the pocket
- uwmcscott
I barely have time to build a sandwich for lunch so these kinds of threads always amaze me - looking forward to your progress.
Busy day in my garden workshop
Started hand carving with the Shinto saw rasp
The foreman was reasonably happy with my work
After quite a few hours with the saw rasp it was taking shape
And then to some sanding
And a test of the planned finish
Just grab a chunk of wood and have a go, worst case you’ve got firewood or sawdust!
Is it exactly how I imagined when I started out? No, I’ve had to adapt due to mistakes or not having the right tool,
Kind of you to say my woodworking is nice, I can imagine the guys that are good at it looking at this and having a wry smile! I’m a total beginner just giving it a go
There will now be a brief pause, I need some stock for the neck.
