Jumping ahead more than a few steps with this pic. Back bracing is complete and the label has been applied.
Martin D-18ish Acoustic Build
- TheIrritableLuthier
The back fitted and glued in place, prior to trimming.
The last thing I did before I shelved this before winter. Installing the end flash.
Picking back up on the build after winter, it was time to start the binding. Here I'm thinning the binding down to dimension on my drum sander.
Next is to glue on some BWB purfling.
Then into the bender.
Unfortunately, this happened in the bender. I'm applying heat and moisture to a glue joint so there's always a risk of something like this happening.
To fix it I cut off the mangled piece of purfling, bent a replacement piece on my DIY hot pipe and glued it back in place.
With that sorted, it was time to route binding channels.
Intellectually I know this is just woodworking, but hot damn this is impressive. Thoroughly enjoying this, as I always enjoy watching someone skilled do something that I can't. Awesome job.
Thanks!Rollin Hand wrote: ↑Sun May 31, 2020 10:09 pm Intellectually I know this is just woodworking, but hot damn this is impressive. Thoroughly enjoying this, as I always enjoy watching someone skilled do something that I can't. Awesome job.
First pass with the router.
Last pass to accommodate both the binding and a layer of purfling.
The final pass to allow the full depth of the binding.
Here I'm mitering the ends prior to glue up.
The first half of the binding all glued up.
After tons of scraping and sanding, here's the final state of the binding.
One final step. Routing the dovetail socket.
Wow, that's looking beautiful!
Time to start working on a neck. This will be a 3 piece mahogany neck, with a scarf joint at the headstock.
Here is my scarf joint jig for the table saw in action on a practice piece.
