Weirdest toggle switch placement in history
I'm trying rationalize the possible justification for that design selection.
The way the edge of the body is routed likely prevented them from putting the output jack there, so that had to be placed at the top.
Where they did put the output jack is where the toggle usually is on a guitar configured like this. Look at most PRS guitars as an example.
They could have put the toggle on the upper bout, like on a Les Paul, but maybe they didn't want to add another step in production by making an additional rout in the body.
So somebody came up with the novel idea of putting it between the strings and between the bridge and tailpiece. While I salute their pragmatic approach, I've gotta say that aesthetically is just doesn't work of me. While it's completely functional, it's not an elegant solution. I can imagine many other options that I'd have preferred, like a mini toggle between the volume and tone knobs, or a slider switch in the same location, or putting the toggle on the lower horn (Explorer placement).
Good points. To me, probably the upper horn would have made the most sense, but like you say, maybe they were trying to avoid the cost and time of another route. Maybe they could have moved the input jack back a hair and squeezed it in between that and the tone knob. Looks like if they wanted to put it on the lower horn they would just made a tiny route to the neck pickup cavity.toomanycats wrote: ↑Fri Jun 12, 2020 6:24 am I'm trying rationalize the possible justification for that design selection.
All in all, very weird placement, and it makes some of Rondo's ocassional wonky design decisions look great.
My playing is always better after some good beer
It's probably that the guitar didn't come with the Bigsby from the factory, but instead had a wrap-around bridge. Still an odd placement but at least makes a little more sense.
Aaron
"What is perfect pitch?"
- LightWingStudios
- Site Admin
Yup
- fullonshred
It is probably a fine guitar, and the switch entirely fine as pictured here. I wouldn't even mind having one. The plateau style top is just not aesthetically pleasing to my eyes though, on any guitar I have seen it used. Either do a proper carved top, or leave it in the LP Jr style.
That was discussed in the forum I saw this thread on, and everyone speculated that had to have been the case, but then someone came in and pointed out that the guitar was indeed offered with a wrap around bridge, or with a Bigsby option from the factory.
There's really no excuse for that placement. There's plenty of room to position it near the volume and tone knobs. They could have even put the switch between the pots like on their LP and SG "Specials". Personally, I don't like that placement, either, but it's better than right behind the bridge.
