It's nigh mint condition too. Really clean.
I gather these sold for circa 1500 new, and they were later replaced with a cheaper version that no longer has DiMarzio US made pickups but DMTs and no set neck either. This is closer to the $3K USA standard model, but doesn't have the binding or block inlays on neck.
In any case, it plays and sounds great. No need to even swap pickups. Frets are quite low, far from jumbo, but I like them lots. Still tall enough that even tapping is easy. Balance is perfect despite heavy Grover tuners. All mahogany construction, the new bolt-on versions have maple necks.
I immediately put in strap locks and black knobs instead of white. Looks better this way IMO and one of the knob hats was broken.
Also swapped the switch position to where it is on my other two Vs, the original position is quite awkward.
My Epi V and Cort V are real nice guitars too but I had to modify them quite a bit to make them good. This is really very nice as is, I don't think I need to mod it any further. Just will double-check intonation once the new strings set in.
I'm a happy camper. Three '58 body style Vs at home is a good place to be
