In case anybody was wondering what a Seymour Duncan Quarter Pound Tele neck pickup sounds like. The Tele in question is a 20th anniversary model Squier Affinity, made in 2002. Alder body, top loader, wonderful petite neck with a maple fretboard (no skunk stripe).
I don't know what is loaded in the bridge position, though it is not the stock ceramic pickup, it has some balls, and it has good tone as well.
And yes, I do find that cats are especially attracted to Teles. Maybe it's the ice picky thing, something about the frequencies being similar to rodent squeaks.
Cats Love Teles
My usual go to recording amp, the 65 Amps London. No pedals, straight into the amp. The front end of a Bluesbreaker type amp sounds so good when pushed by hot pickups.
A Shure SM57 was in front of a Celestion Vintage 30.
Golden Age Pre-73 (Neve 1073 clone)
Apogee Duet
Some compression, eq, and reverb applied in Logic.
Neck pup on the solo licks?
Yes, neck pickup on the tapped harmonics at the beginning, as well as on all the lead guitar.
I only used the bridge pickup for the rhythm arts.
I knew it! I use the neck pup a lot. I used to use it exclusively but now I find a need for the bridge some. The SG Jr only has a bridge pup and that has been a different thing for me. I am getting used to it and I have another single bridge pup guitar in route. Funny how we change over time.
I was a Strat man starting out. I had an SG Standard briefly in the late 70's but it felt awkward so I went back to the Strat type. After about 15 years of that I suddenly decided I like a Tele better and traded my Strat even for a Tele. I was a Tele man and nothing else but during that period. I did discover that I liked a semi-hollow. Then about 12 years in I picked up an Agile LP with P90's and BAM! I became a Les Paul and a P90 fanatic. I still have the love for a good semi-hollow but I do not think I will ever take the stage without a P90 pup there. Through it all though I was a neck pup guy. I will not abandon the neck pup but I am trending towards using a bridge pup much more. To me it almost requires a tweaking of the EQ on the amp.
Due to the massive influence of Van Halen my initial approach to guitar was the opposite from yours. All I cared about was a hot bridge humbucker and a single volume knob. Actually, that's not entirely true, as I really didn't have much use for a volume knob other than as an on/off switch.tonebender wrote: ↑Tue May 09, 2023 8:37 am I knew it! I use the neck pup a lot. I used to use it exclusively but now I find a need for the bridge some. The SG Jr only has a bridge pup and that has been a different thing for me. I am getting used to it and I have another single bridge pup guitar in route. Funny how we change over time.
It took me several years to recognize the beautiful tones available out of a neck humbucker, and even more than that to cultivate an appreciation for single coil neck tones.
What I really like about a hot Tele Neck pickup is that it almost begins to overlap Gibson PAF, Burstbucker type 1 territory. It's got that extra push and fullness, yet is also articulate and biting.
I do like a P90 in the neck position of a Les Paul, and as a matter of fact,my first guitar outfitted like that was an Agile AL.
The best of both worlds from what you're saying would be a semi hollow with P90s. I have exactly that in my Douglas Gravity, which is a semi hollow Tele with two P90s. Plays like a Tele, but lighter, and sounds similar to a 335.
Cats love a Les Paul too. Miss Purrl approves of the Goldtop with P90's.
I think Jimmy Page used a Tele early on where a lot of folks assume he was using a Les Paul.
Yes, this is true. A Tele and a little combo amp created riffs so massive riffs they persist like monuments carved in granite. Jimmy subsequently became so associated with a low slung Les Paul that I suppose it was natural for people to assume that's what he used on the early records.tonebender wrote: ↑Tue May 09, 2023 3:30 pm I think Jimmy Page used a Tele early on where a lot of folks assume he was using a Les Paul.
Fun fact: The guitar solo on "Stairway to Heaven" was played on a Tele through a little Supro amp.
- Narsh
Main Bass: Yamaha TRBX305
Oooh I love that pickup!!! I have one in my Tele as well!!!
