As you can see, neck has come off at some time and repair was ugly. But it reveals the guitar is real wood, so I'm gonna sand it down, at least the backsides, reshape the neck and then see if it's worth putting in new frets.
Probably will have to put in new frets, because the fretboard is nigh flat. Never seen so flat a board on an electric. I should sand it to a nice 15" radius I think and put in SS frets.
That will however also likely require me to lower the pickup rings, they're too high already, and adding to the radius will only lower the strings in relation to the body.
That means also probably shaving a bit of metal from the underside of the bridge, to make super low action possible.
It's a bit of a challenge, but a fun project.
Pickups are surprisingly good, even very nice.
I think it would look good if I shaved the back entirely to wood, dyed it darker brown, and leave the top cream. Maybe give it a faux black binding.
Maybe I'll sand and shape the headstock to Gibson shape, but I'll try to preserve the top & the logo. If that won't succeed...well maybe get some novelty logo for it.
