My shed studio build thread
Buddha Pickups
A different kind of build thread.. I'll try and add more as I go.
Now that I'll be taking a hiatus from pickup making I should get more done on this. These first few posts is what I've accomplished in the last year or so.
I've always wanted a separate studio space I could play guitar or drums in so I started this back in late 2019.
I first had to clear a little space in the woods. I own about an acre of woods so I wanted to use a littlebit of that space instead of using a big spot in my backyard.
Buddha Pickups
Then I added in some material and did a rough level. I had to hand chop all that wood. I did have someone help take out a few stumps though.
Buddha Pickups
Now that I have a rough level, it was time to set some posts in 2' of concrete. I didn't want this sitting on the ground so its roughly gonna be 2' off the ground. I wanted space to get under it easily to insulate as well.
6x6 posts. Shed is going to be 14x32
Buddha Pickups
I unfortunately didn't have the time to build it myself so I hired someone and only got a few pics during the process as I was working.
Leveling the posts and placing the runners then floor joists.
1st wall going up
Inside, when finished. Got a lot of work to do.
Buddha Pickups
Outside. The barn style door ain't gonna cut it so I'll be replacing that first. I also need to add a hand rail.
Door replaced and hand rail added. Also made a new bridge to cross the ditch.
Buddha Pickups
Electricity.
Pain in the arse. I had to dig 18" down and it was about a 100' run from my house to the bridge.
ILuvTeles
Looks good! Door will work much better, too.
Buddha Pickups
I need to take some more pics of the inside but as far as the outside I have tyvek up and will add siding hopefully this spring.
Inside I've insulated the first floor and have all my outlets installed. I'm using safe and sound rockwool insulation and I got 60 sheets of 5/8" drywall ready to go up too.
For a/c heat I have an 18k btu mini split that I need to install.
I just finished putting in the floor joists for the 2nd floor.
I'll get some pics of this and of the inside next time I'm out there.
Buddha Pickups
ILuvTeles wrote: Sun Feb 07, 2021 1:18 pm Looks good! Door will work much better, too.
I figured trying to get a barn style door to keep sound inside was gonna be tough!
ID10t
Looks nice. For that size (easier than messing with a house) I would consider dedicated grounds to each circuit. Make sure you use florescent lights (I kid).
Flatline
That looks great! I built a new shed last year, but much smaller and more for general storage. It is nice to be able to get some crap out of the house. Your studio shed looks awesome!
Buddha Pickups
ID10t wrote: Sun Feb 07, 2021 1:33 pm Looks nice. For that size (easier than messing with a house) I would consider dedicated grounds to each circuit. Make sure you use florescent lights (I kid).
Yep.
I ran 220 from my house, 60A total new breaker from my house and divided the shed into 3 20A circuits. 1 for each long wall and 1 dedicated for the a/c.
A new ground was driven into the ground for the entire circuit.
aullucci
What a payoff that is going to be! Great work, man
fatjack
Look like a great place once it's finished. I think most of us would like a shed like that.
Buddha Pickups wrote: Sun Feb 07, 2021 1:18 pm Electricity.
Beats my extension cords run on the ground through puddles. :) very pro.
Very cool - now that I'm working at home I definitely need something like that.
Very impressive!
Longblacktie
That is awesome! Is it going to have heat?
LightWingStudios
Site Admin
MAJOR Congrats! "Shed Studios" is BORN! :)
devdem
Incredible. I'm so jealous of you guys with the space. At some point over the next few years we will move and I'll find someplace with an acre or two and build a workshop/music shed. Heck even my work-from-home desk is tucked in a little spare bedroom nook.
Well done, keep the pictures coming.
The sheetrock can be put up with a sound deadening caulking compound gooped up each stud, called Green Glue. It's effective. There are videos about using it.
Partscaster wrote: Mon Feb 08, 2021 6:26 pm The sheetrock can be put up with a sound deadening caulking compound gooped up each stud, called Green Glue. It's effective. There are videos about using it.
I've heard a bit about this. I find it very hard to believe you need glue to keep the sound from escaping tightly screwed drywall. Is it really that important?
TVvoodoo
Such a beautiful natural setting? no windows?
Buddha Pickups
Longblacktie wrote: Sun Feb 07, 2021 11:19 pm That is awesome! Is it going to have heat?
Yes, I have an 18k btu mini split and a dedicated 220 circuit for it all wired up. Just need to install it.
Buddha Pickups
I read that as well but it's pretty costly.
I have 3 solutions so far for sound deadening.
1st. I bought 5/8" drywall and enough to put 2 layers on the walls. Standard is 1/2" so im banking on more mass to help.
2nd. I'm using rockwool safe and sound insulation. Much better than fiberglass insulation for sound deadening purposes.
3rd. I've added a layer of moving blankets over the insulation, stapled to the studs. This should add another layer of sound protection while also adding a buffer between the drywall and the studs, similar to what green glue does.
